Air conditioner Indoor Blower Fan Motor Wiring on Universal PCB
i got problem with my Onida Split Air Conditioner 1.0 Ton PCB.
so, i bought a new Universal AC Board.
but, it doesnot have slots to connect all the wires in Indoor Blower Fan Motor.
please see the above attached image.
i have 6 wires coming from fan motor
First set - 3 white wires.
Second Set- Red, Black and white.
but in PCB, i have slots for High, Medium and Low ( i connected it to White , Black and Red).
where i need to connect the remaining 3 wires in PCB,
do i need to modify PCB circuit or can i by pass any setting.
PS: everything works fine, except the fan blower.
Welcome to the forums.
As this is primarily a site based in North America I'm not sure if our regular people will be able to help you. I know when I make a repair like that I only use the control board that is designed for the unit.
For you to make those connections you will need the schematic for the A/C unit showing the blower wiring in detail. If you can point us to an online schematic for your unit we may be able to help you.
More Connection Diagrams of Old and New PCB.
Thanks for the quick reply PJmax.
here i'm attaching 3 more images of both old and new pcb with connection diagrams.
hope you can get a quick solution.
New PCB Connection Diagram:
Connection Diagram Located in Indoor Unit
Old PCB
The problem with old pcb is, the power LED flashes fast with no response to remote. in case, any idea, which component might be gone ?
Old PCB
The connection diagram is just that..... connections for the wiring.
It's not a schematic. A schematic would show the motor wiring in detail as well as function.
You need to know, in detail, the motor wiring colors.
As far as the control board I don't know what the problem is. I can speculate but that would not help you.
please check my first post here. in that you can see the image showing motor with wires coming out.
or do i need to upload any other specific part images ?
i went through your profile. hope you can fix my problem.
Thanks in advance.
Thanks in advance.
see this image(old pcb ).
http://www.doityourself.com/forum/at...ac-old-pcb.jpg
following is assumption:
pair one :
Red - High
Black - Medium
White - Low
pair two
assumed by checking with multi meter)
1st wire - common
2nd wire - some fan control (not sure) have any idea on this wire ?
3rd wire - 5v
let me know your suggestion.
Thanks.
pair one :
Red - High
Black - Medium
White - Low
pair two
1st wire - common
3rd wire - 5v
Thanks.
I recommend getting a matching control board. Trying to make the wrong board work can do more harm than good.
Hi.
Please help! I have a similar problem.
My (very old) air conditoner's PC board packed up. Had no choice but to get a universal board.
One similar as to Anuradhan's.
Same problem - the new PC board (called a QD-U02B) has three ports for the fan (low, med and high). See schematic attached.
The a/c fan has six wires (red, black and white that connected "together" on at "same area" on the old PC board. The yellow, grey and brown wires connected "together" on a different area of the old PC board. Please see photo of schematic on the fan.
What are these wires for? And which of them should I connect to the new PC board?
Thank you in advance!
Just to mention, the black, red and white wires are slightly thicker than the yellow, grey and brown ones. There is a 7th wire coming of the fan, the earth, this one is all that I know...
This isn't easy as there is a language barrier when I look up your components.
Does your blower motor have a capacitor attached to it ?
The motor is a PWM (pulse width modulated) type and gets connected to 220/230v at 50hz. .....using the red, white and black wires. The other three are control wires to tell the motor what to do.
This is the best info I've found on your motor. This info tells me that control of the motor comes from the board. I don't think your universal replacement board will work with that motor. I may be wrong but I can't get any useful info on the control board....especially in English.
http://www.airecontrol.com.ar/info/c...tor_galanz.pdf
You need to contact the board supplier and get recommendations right from them or call in a service tech in your area that may be familiar with your equipment.
For other visitors that come across this thread.
The control board QD-U02B is designed to work with a standard blower motor. That would be a blower motor that has a neutral/common wire and one to three speed selection wires.
It WILL NOT control a PWM type blower motor.... like the ones shown in this thread.
There is a way to connect it, the only thing is that you will not be able to change the speed of the motor.
If you notice, there three wires that are together are thicker than the others. This provides power to the motor. The other ones tell the pcb the motor's speed. You will need to leave the speed sensor cables disconnected as the universal PCB does not use them.
As someone already mentioned, the universal pcb you have is designed to work with motors that have dedicated wires for speed, which is not the case of your motor.
Back to your motor, if you notice your original PCB, there should be a capacitor next to the fan connection. Two of these wires connect to the capacitor and the other one to the neutral wire. You will need to remove the capacitor from the PCB and connect it to your motor the same way it was on the pcb. Just follow the tracks on it.
