construction of concrete base for A/C compressor
Old 04-08-16, 10:44 AM
D
Received 1 Vote on 1 Post
If we construct a concrete base for a new A/C system, I foresee a platform of about 3' x 3' in size. The soil at the base location would be removed to a depth sufficient to allow some gravel to be spread as a base for the concrete which would be several inches thick.
I'm wondering whether rebar should be included in this project?
Old 04-08-16, 11:00 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
They make premade pads for A/Cs.
Old 04-08-16, 12:38 PM
D
The house I'm referring to belongs to my son. I'm aware of the premade pads. I have one of them under my A/C, which is over 20 years old. The pad has settled over the years. We were thinking of concrete as a better, more stable base.
Old 04-08-16, 01:15 PM
C
Received 2 Votes on 2 Posts
Remove grass and loose soil, put down 4-6" of crushed rock, well compacted, and high enough so water drains away and you'll have a stable base. Once you've done that, you might as well put a precast down because it's inadequate base preparation that makes them settle, not the pad itself.
If you really want to pour a slab, you won't need rebar if the base is good.
Old 04-08-16, 01:48 PM
Received 333 Votes on 296 Posts
When I poured the pad for my heat pump I removed the top soil and formed it up [over slate rock] Poured ready mix bags with no rebar. That was 18 yrs ago, it's still level and in great shape.
Old 04-08-16, 07:01 PM
czizzi's Avatar
Received 14 Votes on 12 Posts
The ready made pads are mostly styrofoam with a concrete coating. They are not subject to the freeze/thaw issues that can happen with concrete. Just something to consider in a northern climate.
Old 04-08-16, 07:30 PM
Received 79 Votes on 74 Posts
Whole lot cheaper and faster to use a preformed pad.
Old 04-08-16, 11:59 PM
A
Received 46 Votes on 41 Posts
What's the opinion of the plastic pads? I've used them over a rock gravel base with no issues.
Old 04-09-16, 01:29 AM
Handyone's Avatar
My A/C has been sitting on a plastic pad for about 10 years, no issues.
Old 04-09-16, 05:57 AM
Former Member's Avatar
Dig down below your areas frost line by at least a few inches and gravel so it does not shift during freeze/thaw cycles. Pour a min 3in deep pad with quikrete concrete mix for a condenser. No reinforcement is required if the gravel base is good.
Old 04-19-16, 01:46 PM
D
Does this mean a concrete product, or is it made of some other material? Where are they sold?
Old 04-19-16, 05:15 PM
A
Here is a 72 lb. one you can have shipped! Equipment Slabs | CONCRETE REINFORCED EQUIPMENT PAD | 2424CONCPOOLPAD 24"X24"
Precast are generally solid concrete but they do make hybrid ones.
Plastic ones you can order at the big box stores.
Old 04-19-16, 06:34 PM
G
Wow, the shipping would make me get 3 or 4 bags of premix and short rods of rebar and form up my own which I did, but for a 100 gal. propane tank that I no longer have. For my a/c I have and used 2 concrete curbs from a nearby plant.
Old 04-19-16, 07:58 PM
czizzi's Avatar
The preformed ones around here are 90% styrofoam with a concrete shell. Light enough to lift with one hand. Continue your search.
