Most silent AC unit?
Old 05-27-16, 04:49 PM
D
Received 1 Upvote on 1 Post
I have currently a Comfortmaker AC unit.Name:  IMG_0395.jpg
The unit is probably about 15 years old and generally in good shape. However, I believe it needs some service. Air is not as cold anymore as it used to be.
I am sure it could be serviced.
However, since it is mounted beneath my deck I am considering to replace the AC unit to reduce noise.
My questions:
1.) what brand/product line is considered most silent?
2.) Can I upgrade just the outside AC unit (not replace the furnace and AC coil)?
Old 05-27-16, 05:49 PM
E
Received 5 Upvotes on 5 Posts
I think consumer reports check for noise, you could start there.
Beyond the model though, putting a layer of noise isolating foam over the concrete base made a huge difference for me.
Old 05-27-16, 07:51 PM
Received 3,897 Upvotes on 3,494 Posts
An A/C condensor under a deck is a less than ideal location for it. Many of the quieter/higher efficiency units are taller and need more clearance over them for airflow. That will need to be considered when purchasing a replacement.
On a 15 year old unit..... if you decided to replace rather than repair..... you'd want to change the condensor and the coil.
Be sure to get several quotes on new equipment.
Old 05-28-16, 05:24 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I agree with Pete on the location under the deck as being less than ideal. I had mine replaced by a "hardtop" model of Trane, forget the number. But the blade is like a gossamer and turns very slowly but moves a bunch of air. It is barely noticeable unless you are near the unit.
Old 05-28-16, 06:47 AM
D
Unfortunately, I am restricted with he location. It is a row townhouse where the deck spans the entire with of the unit. However, the deck is 7 ft above ground.
BTW. would a unit like this have advantages?
Performance Compact Central air conditioner – NH4A4 | Comfortmaker
Seems like it has a low SEER rating?
