Fuse vs Circuit Breaker
Old 06-19-16, 11:31 PM
WRDIY's Avatar
Received 41 Upvotes on 39 Posts
Each spring or summer, I usually climb up to the attic to check my gable attic fan. I also remove the panel to the condenser to do a visual check of the capacitor and hard start kit. Before I remove the panel, I pull out the fuse. Is this good enough to avoid electrocution of 240 volts or should I also shut the circuit breaker switch off too? I know the capacitor still holds a charge so I am very careful not to touch it or short it.
https://www.dropbox.com/sh/es52l9rin...E-5eEWsla?dl=0
Old 06-20-16, 12:04 AM
Received 3,750 Upvotes on 3,362 Posts
Pulling out the fused disconnect kills the 240v supply to the condensor.
The capacitor shouldn't hold a charge on power down.
If you want to make sure.... short the leads to ground with a screwdriver.
Old 06-20-16, 12:05 AM
Houston204's Avatar
Received 90 Upvotes on 83 Posts
Pulling out the fused service disconnect is sufficient.
Old 06-20-16, 12:09 AM
WRDIY's Avatar
Thank you PJMax and Houston204!
