What size unit is this?
Old 08-06-16, 07:11 PM
cheese's Avatar
Received 55 Votes on 50 Posts
I'm trying to find out the size of this unit, Heil model NPADC41AB03 it also has the number 867.819242 in the model area. It say style no. 41mpc-000085cr . Any ideas?
Old 08-06-16, 11:51 PM
Received 1,522 Votes on 1,405 Posts
It's a package unit and looks to be 4 ton unit. A similar unit is on the obsolete list at ICP/Heil.
The 867 number looks like it might have been sold by Sears in Canada.
Very little info available for it.
Old 08-07-16, 12:57 PM
cheese's Avatar
I was thinking sears too with that 3 number prefix. Thanks for the info, I am looking to put it in service at a 14X80 foot mobile home rental property I own. It has a 3 ton Carrier right now and it isn't keeping up with the heat. The home is in the full sun all day and when the temp is 95 and up the current unit can't keep it under 80. I had it checked and the AC guy said it is doing all it can and that I need to go to a 3.5 ton and maybe a 4 ton wouldn't be too much. I can get this unit for $200 in working order, so I figured that's an inexpensive solution if it's bigger than 3 tons. Are you pretty sure it's more than 3?
Old 08-07-16, 01:04 PM
It looks to be pretty old. Not much info online. It does link up to Sears and based on the part number of the compressor used it shows as 3 ton. It also shows ten different compressors which may mean it could be larger. You may need to get the part number off the compressor to confirm.
SEARS Air Conditioner Functional replacement Parts | Model 867819242 | Sears PartsDirect
Old 08-07-16, 06:36 PM
cheese's Avatar
Yeah, it's old. It has been in storage for a long time. Still charged and looks decent though. I don't know, I just don't want to go 2500 for a new unit right now. I may wait and see how the current unit keeps up after I put the new roof on. I'm putting a beige metal roof over the existing one with a 1" air gap between the two, so that should help a bit.
