Return and supply-temperate difference 13-14 deg
Old 08-22-16, 03:43 PM
R
Return and supply temperature difference 13-14 deg
Hello, my AC remains at 73-74 throughout the day and most of night even though thermostat is set to 70. Inside humidity is at 54-55%. Outside temp at around 10am is in the 80s and rises to 96 at hottest point.
I have an AC maint contract and maint was done a few days ago, and tech said all was fine. However, unit did not behave like this last summer. It would go to 70 during day if I set to 70 or 69 at night if set. Now it's midnight and it still does not drop to 70.
I tested temp at return and various vents from closest to furthest out from unit, using a digital thermometer w probe. The temp difference ranged from 13-14 degree from return to the various vents tested.
Is this normal, or is the unit with possible issues?
The AC unit is a Trane 20xi
Would greatly appreciate any feedback.
Thanks,
Old 08-22-16, 04:08 PM
Tolyn Ironhand's Avatar
Received 568 Votes on 487 Posts
Welcome to the forums!
I have relocated your thread to the Air Conditioning section.
Old 08-22-16, 09:33 PM
C
Received 4 Votes on 4 Posts
13-14 degree split is a little too low, you want 16 at least.
Old 08-22-16, 10:02 PM
Received 2,809 Votes on 2,541 Posts
Welcome to the forums.
A agree.... the split is too low.
Since the registers are so close in temperature it appears that the ductwork is insulated pretty well.
Has the filter been serviced ?
Basic maintenance would not include checking the refrigerant charge but it may be required in your case.
Old 08-23-16, 05:18 AM
R
Waht is the temperature of the attic. Extreme temps cause big losses.
Old 08-23-16, 12:28 PM
R
Thanks all for your input. I replaced filter on day of maint <7 days.
Attic temp is currently at 90 and Outside at 94.
Thanks,
Old 08-23-16, 07:22 PM
Houston204's Avatar
Received 34 Votes on 30 Posts
That unit has 2 compressors. A small one and a large one.
I would try to prove that the high speed compressor is kicking in when the cooling demand is greater than 2 degrees.
If you stand next to the outdoor unit while someone turns on the thermostat to cool mode with a 1 degree demand and listen to the unit run then have them increase the cooling demand to 3 degrees you should hear the unit run louder.
Old 08-24-16, 10:57 AM
HVAC RETIRED's Avatar
The indoor humidity is the biggest factor affecting the indoor temp-split; CFM airflow has a lesser secondary effect.
At an indoor 74F dry bulb & 55% RH that is an indoor wet bulb of about 73F, therefore the indoor temp-split should be around 19F; not 13 or 14F.
The higher the indoor humidity above 50% the lower the temp-split; at 71F WB or 86.5% RH the temp-split is only about 11F.
If Tech added refrigerant it could be overcharged now...
Old 08-24-16, 07:52 PM
R
Tech came by today and checked charge and said it needed some. Now it's cooling again to 70.
I also lowered the humidity to 50% tonight and will run it like that moving forward.
Greatly appreciate all your assistance.
