Service valve leak - repair or not?
I am a home owner. 17 year old 10 SEER Rheem 2 ton. Freon leaks. Service engineer found leaky service valve, the one with snap ring. Schraeder valves may leak, too, but they are minor in repair cost.
QUESTION: I don't want to spend hundreds of dollars on this old system. How would you advise? Thank you.
What's better.... a hundred dollars on repairs or a hundred dollars on refrigerant every year ?
If you don't spend the money on the repairs what are your plans.... replace the system ?
