Is it necessary to have a float switch installed for your home ac?
Old 09-23-16, 08:42 AM
The ac tech is recommending a float switch for my ac unit. He is going to install a splash guard (water is leaking into drain pan) and in addition he is recommending for a float switch to be install.
My house is build in 2013.
Old 09-23-16, 09:59 AM
Received 3,753 Upvotes on 3,365 Posts
If the air handler is located anywhere where if it overflowed it could cause water damage.... then a float switch is definitely recommended.
Old 09-23-16, 10:00 AM
P
Received 2,010 Upvotes on 1,802 Posts
Float switch on what or where? Do they want to put a float switch in the catch pan, condensate sump or where?
Old 09-23-16, 02:35 PM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
Code in most areas. Cheap insurance.
Old 09-23-16, 08:12 PM
Float switch where the pipe flow the water into the 2 secondary drain pan, in case it overflows then it will shut off the ac.
I live in Texas
