Installing delay timer in a heatpump
With help from a super nice guy named Pete on this forum, I have learned my heatpump has a bad delay timer. I've received the new one he suggested. First off I'm completely DUMB when dealing with anything electrical. This is why I'm asking the question. I don't want to blow anything up after all of his hardwork helping me figure it out. I just want to make SURE that when installing the timer that the yellow (power) wire from the thermostat (coming from inside) in fact connects to the input wire on the new delay. There are 2 wires (both black) coming from from the delay. Input (24VAC) and output (Load 15AMP MAX). From what I see on the instructions, it appears the thermostat connects to input (24VAC) and the output (Load 15AMP MAX) to the contractor which goes to the capacitor. Is this correct? The instructions then go on to talk about testing for a trickle current bypass resistor T1-T3 < 1k ohm. How would test the trickle current bypass it mentions?
Thanks to anyone who can help! It's much appreciated!!
Wendy
Wendy
I'll add this to your thread.... later.
The new timer connects just like old one.
The 24vac in is the little olive green wire from the house.
The output load is the heavy yellow wire that goes to the contactor coil.
So it goes where you currently have a temporary splice.
