Window AC Unit Tripping
Old 05-18-17, 05:22 AM
C
Hello,
I have a 1 year old Haier AC unit, 5100 BTU, 4.0 amps. After running for a bit the unit trips the breaker at the end of the cord. This will happen every time a light switch is turned on OR just randomly after running for a bit. The cord and breaker at the end don't seem to be getting hot, but I can't get the AC unit to run for more than 10mins.
I live in an old apartment. Main circuit breaker was actually replaced last year when the hot water tank was changed from natural gas to electric.
Also, in the same apartment I have a 10,000 BTU AC window unit, 8.8 amps that has never tripped the cord breaker.
I also tried running this AC unit in a different apartment upstairs and same thing happens. A light switch is turned on and the AC unit trips off.
Is there hope in saving this AC unit? It is only 1 year old and would be a damn shame if I can't fix it or get it fixed for low cost.
Thank you for your help.
-Colin
Old 05-18-17, 05:26 AM
C
Just did a little test. Since i have no idea what outlets go to what circuit in my apartment, I unplugged the fridge and the bigger AC unit (two of the biggest amperage drawers in the apartment). I ran the Haier unit, flipped the switch in the same room and it tripped off...
Old 05-18-17, 06:08 AM
ray2047's Avatar
Received 15 Votes on 13 Posts
That is not a switch. It is not a breaker. It does not trip due to an overload. It is a LCDI (Leak Current Detection Interrupter) that trips due to current leakage in the A/C often due to a bad cord.
Old 05-18-17, 06:09 AM
Bob14525's Avatar
Received 48 Votes on 41 Posts
Since the unit is tripping the internal breaker (the one built into the plug), it would appear (to me) that the internal breaker is defective. I don't know if you can buy a replacement "plug", but if not, I would buy a new plug and just cut off the current breaker/plug and install a simple plug. If you want to be extra safe, you could install a GFCI outlet where you plug the A/C into. I'm guessing that there may be the equivalent of a GFCI built into the current plug.
Old 05-18-17, 06:15 AM
ray2047's Avatar
Not a breaker but a device similar to a GFCI, a LCDI (Leak Current Detection Interrupter). The cord contains a molded in metal shield and that reacts to faults in the cord. Replacement cords are expensive.
Old 05-18-17, 06:25 AM
C
Any idea what replacement cord i should look be looking for?
I am willing to buy a replacement cord and install it. This unit cost around $130 a year ago....
I found this:
Name:  Haier AC Cord.jpg
https://www.repairclinic.com/PartDet...s=a16b198&mr=0
Old 05-18-17, 06:31 AM
C
I found the correct cord that fits my model.
https://www.repairclinic.com/PartDet...8d2132549&mr=1
Old 05-18-17, 06:35 AM
ray2047's Avatar
Best to buy one recommended for your unit. If that is recommended for your unit it is a good price. Of course it could be something else but you don't know till you try.
I'd just replace the A/C so you don't end up spending the cost of a new unit or more before you fix it if you do fix it.
