wire size for mini split
minimum circuit capacity 15a
maximum fuse 20a
So I use 12-2 wire with 20 amp breaker?
maximum fuse 20a
Welcome to the forums.
12/2 is good for up to 100'.
Keep in mind you will also need cable to connect inside to outside unit.
Some units use three wire and some use four wire cable.
