Suction line insulation deteriorating
Old 07-25-17, 09:40 AM
A
First time poster and I would like to get an opinion on what could cause this. The suction line insulation before the compressor is deteriorating at a rather rapid pace. There is a large wet spot under it on the concrete. The foam is soaked. Smells like water but not sure if gas is leaking out. Not sure what could cause it.
Old 07-25-17, 01:29 PM
A
I realize sweating is normal, but the unit next to it isn't sweating and the foam seems to be falling apart it's so wet.
Old 07-25-17, 01:33 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Likely getting a little more air and moisture in and sweating more. If a Freon leak there might be oil or feel oily.
Old 07-25-17, 01:57 PM
Received 1,119 Votes on 1,039 Posts
As the foam gets older it hardens and crumbles. It just needs to be replaced.
Old 07-25-17, 04:35 PM
A
It feels a little slick. No smell. I'm wondering if the deterioration of the foam is making it slick. Thanks for the replies. I'm only worried because that other unit looks to be in better condition and they are a little over 3 years.
Old 07-25-17, 08:25 PM
The black foam has oil in it from the production process. It could be separating out.
If the foam is not sealed all the way back to the conditioned area... it will sweat inside and run to the lowest point which is right there at the condensor.
