General AC theory Q
General AC theory Q
Had to have a small refrigerant leak fixed yesterday afternoon just downstream of the compressor. After the repair the house got back down to normal inside temp. My wife and I both thought the house was more comfortable and "cooler" even though the thermostat was set as usual.
My theory is that as the system was loosing refrigerant it got less efficient at dehumidifying, even though it would keep the temp okay. With a full charge again it's now at optimal operation for cooling AND dehumidifying.
Did I get this right?
Not an air conditioning guy but your thinking sounds right to me. There is probably an operational curve from too small to too large and you moved up towards the peak a bit. Funny how the human senses can out perform meters some times.
Bud
Bud
I think with less refrigerant the system actually gets colder, which results in less run time--and not enough moisture condenses out to be removed. I think. As more refrig. leaks out it gets so cold it just ices up.
I really don't understand it either. This summer my car AC quit & I had a leaky hose replaced & the system recharged. Now it's so cold in the car I have to set the climate control to what SHOULD BE a ridiculously warm setting.
