HVAC Stystem outside fan not working
Our HVAC System has been fixed multiple times with the blower motor and the capacitor and the heater coil relay. Now the outside fan that sucks all the hot air out will run for like an hour than it will shut off, the temperature is set to 75 degrees but once it shuts off it won't turn back on. Plus the fan motor is burning hot. I'm not sure what is causing it. Could it be a relay or is the fan motor going out?
Welcome the the forums.
Not likely a relay.
Possibly a defective motor but more likely a defective capacitor for the fan motor.
Not likely a relay.
