Auxiliary drain overflow switch
Old 02-17-18, 07:00 PM
K
I need some advice in installing a float switch to turn off the a/c in the event that the main drain is clogged.
I live in a condo and have the air handler above the ceiling in the closet. I see that the aux drain is just pointed down and isnít connected to anything, meaning that the water will just pour on the ceiling! So I was looking at the Safe-T-Switch Model SS2. Looking at the picture, whatís the best way to install it?
Old 02-17-18, 07:13 PM
Received 1,331 Votes on 1,230 Posts
I don't see the primary drain connected either.
There should be an overflow pan under the entire unit.
Old 02-19-18, 07:20 PM
K
I think the main drain is on the other side of the unit the white pipe on the right of the picture
Old 02-19-18, 07:46 PM
That kit comes with the float switch, right angle fitting and a fitting for attaching to the air handler. The air handler thread on adapter is the wrong gender. You'll need to pickup one similar to what is there now a short piece of 3/4" pvc pipe. You'll unscrew the fitting pointing down and replace it with the new parts and the right angle fitting where the switch goes in will be pointing up.
You'll need to locate the thermostat wiring where it connects to the air handler. You can take a picture and post it so we can tell you what to connect to or find the yellow wire from the thermostat and connect the float switch in series with it. When the float is activated.... it will turn the compressor off.
Old 02-19-18, 09:30 PM
K
I think I understand what youíre saying, change out the 90 degree elbow from air handler with a straight portion that you drew that has the correct gender as the switch portion. What about the SS-1? Would that be a better option?
Old 02-19-18, 10:47 PM
Samef difference. The fitting for the air handler end is still backwards.
Old 02-24-18, 10:45 AM
H
Received 1 Vote on 1 Post
Draining
As stated, it appears to look like the primary drain point down as if the trap was removed, itís hard to tell from a picture which one is higher in elevation. Sometimes, Primary and secondary taps are accessible, again, sometimes on both ends. But first, where is the secondary pan? It seems to be missing. They are required for above ceiling installs, especially hard ceilings. To install the float switch. Remove the 3/4XS female adapter, install a new one, extend it a few inches till it clears the cabinet, install a 90 and then the float switch.
Old 03-01-18, 07:57 PM
K
I just installed it like this and used the Y wire, I lifted the switch and it turns off the air handler and I guess the compressor at the same time? That’s normal right?
Old 03-01-18, 09:42 PM
The Y wire should only operate the condensor/compressor. Opening it should not turn the fan off. Opening the R wire should shut system down.
You could post a picture of the wiring there.
Old 03-01-18, 10:27 PM
K
Now it doesn’t look like I’m getting any heat or cool... but the fan turns on. And I checked the condenser, it clicks once when I turn on the heat/cool, but the fan on the condenser isn’t turning on!
Old 03-01-18, 10:32 PM
Could those splices get any tinier.
Power should be off when working on the wiring to eliminate any unintentional shorts to ground.
If you are using the red wire for the float now.... and the system isn't working..... the float is tripped.
Old 03-01-18, 10:34 PM
K
I used the yellow wire... now Iím scared I broke something
edit: now the condenser is turning on
Old 03-01-18, 11:34 PM
That's a picture of the outside condensor. No connection made there.
Old 03-05-18, 05:44 PM
K
I guess I can do the R wire... at least that way I'll know the float switch tripped because everything would be off
Old 03-05-18, 07:01 PM
There should be 5 wires to the outside condensor where you posted the picture. Those 5 wires probably connect in that junction box you also posted but I can't see the splices to advise any further.
There should be a yellow to yellow splice in that box but colors may have changed. You could check at the thermostat and see if yellow is on the Y terminal.
Old 03-06-18, 01:46 PM
K
Yep, I changed it to the Y-Y splice, initially I found a Y-G splice, which i guess was going to the air handler. Now it works! Hopefully I glued it on right and it doesnt leak! Thanks!
Old 03-06-18, 05:53 PM
Good job. You now have a security net but don't forget the main drain line should still be cleaned every year.
