Air handler installation
Old 04-07-18, 01:48 PM
trent38's Avatar
Hi guys, im new here and was looking for some advice. Im interested in replacing my old dinosaur a/c. I already got Air handler and wanted to install in it crawl space. My crawl space at entrance is around 6 foot tall. I believe this would be perfect.My question is i have only seen this done but not attempted it. The original heat pump was package unit and almost 30 years old. This unit is split.All the ducts come in almost where i want to place air handler. I wanted to install air handler and get someone to come out and test system and get it going. Is this something some one can do that is mechanically inclined. Anyone give advice on exactly where to start.Thanks for all help
Old 04-07-18, 03:37 PM
Your biggest problem will be to find some one to do that. Most pros don't want to do that, it gets them involved with the warranty.
Old 04-07-18, 05:47 PM
R
Received 109 Votes on 103 Posts
Why not just put in another package unit?
How did you know what indoor and outdoor unit to buy?
Old 04-07-18, 06:29 PM
trent38's Avatar
well one reason is this unit is brand new and was given to me ..high performance carrier but its split
Old 04-07-18, 07:34 PM
R
Is it the right size for your house? Do you have the ductwork to accommodate it’s required airflow? How about power? You’ll also need to run a new power circuit to the crawl space.
Old 04-07-18, 10:22 PM
trent38's Avatar
yes its same ton as original heat pump.. The duct work is like 8 foot from where air handler would be and.Im already working on power and stuff
Old 04-07-18, 10:34 PM
R
What tonnage is this unit and what size is the duct it’s connecting to? What material is the duct made from?
Just because it’s the same tonnage doesn’t mean it’s right. Did the old unit cycle on very hot or very cold days?
Did the unit come with an electric heat strip?
Old 04-12-18, 05:09 PM
trent38's Avatar
Need help with air handler install..
Hi guys, im in need of some help installing air handler. When we purchased the house it had a package unit that was on its last leg. The original home owner had purchased a brand new carrier but its a split. I really want to use the split since its already here. I was hoping to install the air handler in crawl space. This crawl space has a height of roughly 6 foot. What i wanted to do was install air handler , in a place, that is 8 foot from the original ducts that went into package unit. Then build a base to put it,hopefully vertically, and hook up duct work. Then let tech charge it and test.Has anyone here do this sort of thing.Thanks
Old 04-12-18, 05:14 PM
trent38's Avatar
for some reason this double posted me..please refer to earlier post
Old 04-12-18, 05:38 PM
R
Is this a heat pump? Is the new equipment the same size as the old unit?
You’ll have to run new electrical service. And a lineset.
What size is the unit and what size and material is the ductwork?
Seems like it would be easier to just install a new package unit.
Old 04-12-18, 07:15 PM
Received 1,321 Votes on 1,221 Posts
Threads combined.
You posted in A/C systems forum and heat pump forum. Which is it ?
Old 04-15-18, 11:47 AM
R
I wonder if the OP realizes there’s replies to these threads. 2 different threads on the same subject and they haven’t replied to either of them.
The OP was on yesterday.
