Portable air conditioner broke -- what are these objects in the vent hose?
Old 08-08-18, 12:57 PM
My air conditioner has broken. I took off the ventilation hose to investigate and found some things in it. What are they, what has happened, and is there anything I can do to fix it?
The unit:
The things:
Grateful for any help
Old 08-08-18, 04:50 PM
P
Received 684 Votes on 631 Posts
It looks the the louvers of an exhaust vent.
Old 08-08-18, 05:11 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Looks like blades from squirrel cage (blower)
Old 08-08-18, 05:18 PM
Received 1,194 Votes on 1,105 Posts
Welcome to the forums.
You said your A/C broke. Is it dead...... not even the front panel lights up ?
What is the model number of it ?
I agree with fins/louvers to a vent. They look to big for fan blades.
Old 08-09-18, 02:24 PM
Not dead -- lights are on, it responds to the remote, outlets work, and I wouldn't be surprised if the heat exchange etc. also works. The one thing I definitely know is broken is that it no longer blows hot air out of the exhaust vent.
It's a Duracraft AMD 8500E.
Old 08-09-18, 02:28 PM
If it is moving air then the blower is ok. It sounds like the compressor is not running. If there is a condensate storage tank on the unit.... make sure it's empty and the float isn't stuck.
Old 08-10-18, 12:57 PM
The exhaust vent gets hot when it's running, it just doesn't blow out any air. I looked inside and there were more louvers/whatever down there:
I'm trying to open it to take a closer look but the covers seem stuck together at the top. Not sure if I've missed a screw or something.
Old 08-10-18, 02:35 PM
R
Received 104 Votes on 98 Posts
Looks like your exhaust blower wheel blew apart.
Old 08-10-18, 03:21 PM
Andrew's Avatar
Received 14 Votes on 10 Posts
The blower wheel definitely blew apart. Those are the remnants.
Andy
Old 08-10-18, 05:04 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Since it appears to be a one tube model even if repairable probably isn't worth repairing because one tubes are inefficient. Best to replace with a two tube model.
Old 08-11-18, 08:24 AM
OK, thanks everyone. Is it worth fixing?
Old 08-11-18, 08:52 AM
R
If you can do it yourself, maybe.
Paying someone else to do it, you quickly pay more in repairs then a new one would cost.
You’ll have to dig to get to the blower.
Old 08-11-18, 09:33 AM
I didn't locate any parts distributor that would have the parts you need.
You could check at a parts retailer in the UK.
Old 08-11-18, 12:24 PM
H
Received 111 Votes on 97 Posts
How old is it? Any chance it's under warranty or has a recall for the squirrel cage blower?
If it's older, than it MIGHT be worthwhile to pickup a used-but-working version of the same model from a thrift shop or yard sale, keep this one for spare parts, but it really depends on whether the unit is constructed so that you can replace pieces.
Only good thing, if it's cheapish plastic cage fan, that woudl seem to en I'd suggest that they bought off-the-shelf parts or a standard sized fan.
Old 08-11-18, 08:20 PM
There is little to no info or parts available for these units. I traced the company to a manufacturer in China but they do not sell parts. I happened to see this on amazon/uk. Maybe you can get info thru them.
amazon/uk/Special-Duracraft-8000BTU-Portable-Conditioner
