Universal Transformer
Old 12-01-18, 10:03 AM
T
Lightbulb Universal Transformer
Inline voltage is 2 lines of 120v and I have the transformer wired in for 240v (in) and 24v (out).
When I take a voltage reading it says 27v but shouldn't it read 48v? Pic is attached.
Name:  Transformer Reading.jpg
Old 12-01-18, 10:30 AM
Houston204's Avatar
Received 38 Votes on 34 Posts
I would expect 24 to 27 volts if it is a standard HVAC 24 volt transformer.
Old 12-01-18, 10:39 AM
A
Received 79 Votes on 71 Posts
A "universal" transformer has several leads on the primary to deal with 120, 208, or 240 VAC input so that the output is 24vac. A fixed 120 to 24vac transformer would indeed output 48vac with a 240vac input. Using the universal transformer's 120vac taps would also yield 48vac.
Old 12-01-18, 11:13 AM
Received 2,956 Votes on 2,667 Posts
Yep..... and it would be smoking heavily before it fried.
Old 12-01-18, 11:43 AM
T
Transformer Wires are:
White = Common
Black = 120v
Red = 208v
Orange = 240v
I'm using the White and Orange wires for 240v
Old 12-01-18, 12:13 PM
A
I haven't done that in a while. Sometimes the smell isn't that bad.
Then it is doing exactly what it is supposed to do - providing 24vac.
Old 12-01-18, 01:43 PM
T
OK I have one more question that ties into this ...
Does this mean it only takes 24v to power the fan switch and sequencer?
I watched a few videos where it has mentioned that they require 48v. I'm wondering if they is wrong.
Old 12-01-18, 01:51 PM
99.9% of HVAC equipment, controls, thermostats and relays run on 24vAC.
Old 12-01-18, 03:41 PM
T
Thank you for your help everyone !!!
