Preferred make of A/C for a replacement?
Old 01-13-19, 05:22 PM
D
Received 1 Vote on 1 Post
Looking for you pros preferred A/C make for a replacement air conditioner & air handler? thanks
PS: pros & cons
Old 01-14-19, 02:43 PM
airman.1994's Avatar
Received 8 Votes on 8 Posts
Preferred brand is the brand that is installed correctly. All brands can be installed correctly but I see better installs on the higher end (name brand ) equipment. Trane, Lennox, Carrier. This will help but not a guarantee you will get a good install. Id get quotes and don't use the company that don't do a heat load with a normal quote.
Old 01-14-19, 02:57 PM
D
Thanks airman. 1994...............
Old 01-14-19, 03:25 PM
Received 1,201 Votes on 1,111 Posts
I agree. I like Rheem for good performance to cost. Goodman and Carrier are good alternatives.
Trane and American Standard are high end benchmarks but can be costly to service.
Two points to remember.....
1) The install is key to a long lasting system.
2) The higher the efficiency....... the more the energy savings..... the more costly to repair.
Old 01-14-19, 06:39 PM
D
Thanks Pjmax.............
Old 01-14-19, 08:36 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
Depends where you live kind of... Tempstar or goodmen IMO
Old 01-14-19, 08:39 PM
D
Thanks lawrosa.....................
Old 01-15-19, 05:44 AM
L
Received 4 Votes on 4 Posts
If cost is a factor you can consider buying a Goodman (or a limited number of other names) online and save a lot. There is a place in Florida that sells these units with everything you need at a considerable discount to local prices and I believe they have a list of approved, licensed contractors you can contact near you for the install work.
Goodman is often considered "builders grade" but they are good units with a good warranty.
Old 01-16-19, 02:51 PM
Nothing but issues with Goodman. Junk just like LG IMO.
Old 01-16-19, 03:00 PM
D
Thanks airman. 1994 & lakeseed
