Air Con at night does what it wants
Hi Guys;
i have Fujitsu 2 part aircon system 10kw. i have factory reset, it is set to cool and max fan 20 degrees...in a server room. The room is a constant 22-23 degrees (alot of servers). however the air con random must stop working when it feels like it during the night.
I have installed a 24 hour monitoring temp...for you to see the not so patterns over a 24 hour period over a few days. Any advice well come please it has me stumped, we've had it serviced and the engineers dont know either.
The following users liked this post:
It appears to be happening when the sun is down.
The outside temperature is very important as the condenser may have low outdoor temperature protection.
I had a small workshop that I required A/C in even when it was fairly cool outside. I added a high pressure switch to my split unit and had the condenser fan cycle to maintain a higher head pressure for low temperature stability.
I was thinking it was freezing up however during the winter it has been fine; just only started about a month ago. its like something has changed in it.....really annoying... thanks for the ideas any more welcome...
You said it's been serviced.... I'm wondering if they checked the charge.
Low on refrigerant could cause that problem.
