Would like to make this Amcor mf8000e work sooo hot in room
Old 09-21-19, 10:37 PM
L
I have cleaned filters still hot no sign of coolness to come out of this air conditioner Also not sure how this buttons work or what their function is.
Old 09-22-19, 10:17 AM
Received 3,951 Upvotes on 3,544 Posts
Welcome to the forums.
I've been reading about a large amount of refrigerant leaks in these units. That is a very common problem especially in roll around units. Once the refrigerant leaks out..... that's the end of the unit.
I used the manual that looks similar to yours.
The yellow button is power.
The red button selects mode. You want the snowflake lit for cooling.
The green button is fan speed - high or low.
When the unit is cooling and the compressor is running.... the red light by the blue arrow should be on. If it's on and you aren't getting cold air..... most likely the charge has leaked out.
User manual
