A/C acting weird. Need help before calling pro
Old 04-13-23, 10:47 AM
A/C seems to be short cycling. The blower fan will kick on and off 10-15 times in succession, then stay on for a minute or two, then shut off for around 5 minutes, and repeat. The air that it's blowing is cold, and the condenser fan on the unit stays on. Can hear what I think is freon running coming from the blower unit. Installed a Nest thermostat in the winter that worked great for controlling the heat, but has only used the A/C the past 3 days and no issues were noticed then.
Any Ideas?
Old 04-13-23, 11:24 AM
R
Received 199 Upvotes on 181 Posts
Does the Nest have a common wire?
The Nest has proven extremely unreliable and problematic. And routinely causes issues like what your experiencing.
Old 04-13-23, 12:21 PM
No common wire, but it's not having issues with the nest losing power. Can still turn the fan on and off manually
Old 04-13-23, 02:11 PM
Received 4,051 Upvotes on 3,634 Posts
When you leave it in FAN ON mode.... all is ok ?
If yes.... sounds like a stat problem.
Houston204 voted this post useful.
Old 04-13-23, 05:11 PM
R
Power to the Nest isnít affected. Itís the way the Nest uses the conductors in the thermostat wire that causes the unit to act erratically.
The Nest needs a common wire despite what their instructions claim.
Iíve pulled many of these off the wall due to erratic, unpredictable behavior.
Personally speaking as a 21 year professional tech I wouldnít have a Nest if you gave it to me.
