Secondary Drip Pan Replacement
Old 07-26-23, 06:56 PM
B
I have read all kinds of articles pertaining to the actual pan replacement but none of them show how to get the new pan into the attic through the opening. I can understand removing the old pan (I hung my unit a few years back) cutting it to remove, but getting the new one in the attic is my question. Can someone please shed some light on this subject?
Thank You,
Bob
Current pan size
Old 07-27-23, 05:01 AM
P
Received 2,228 Upvotes on 1,988 Posts
Hopefully the scutty/access hole to your attic is large enough for the new pan. If it's not you'll have to enlarge it or cut out sheetrock between the ceiling joists to make a big enough opening to get it into the attic.
Old 07-27-23, 06:40 AM
Kooter's Avatar
Received 88 Upvotes on 81 Posts
OP = How would your air-handler/furnace be replaced when the time comes for new one if the access is too small to fit a secondary condensate drain pan?
Old 08-02-23, 04:45 PM
Received 4,051 Upvotes on 3,634 Posts
The narrow side of the pan is 28". That would need to fit thru the diagonal of the opening.
