How to bypass outside safety sensor on window unit
Old 11-27-23, 06:50 PM
I have a keystone kstaw08inv-hc window unit that has heat also and when itís below 40 outside it wonít run the heat the unit is in an extra room that was added to house
Old 11-27-23, 08:08 PM
Tolyn Ironhand's Avatar
Received 866 Upvotes on 729 Posts
The unit is a heat pump and will not work properly when the outside temp is below 40 degrees. Bypassing the outside sensor will not be helpful and could damage the unit.
CircuitBreaker voted this post useful.
