Finishing basement- fresh air ducting and drywall questions
Received 0 Votes
Thanks for reading.
Working to finish basement, but this is something I do not know the answer to.
I am looking at how I will need to finish the ceiling in a room with drywall, but there is a 7ftx2ft corner of the room that is sheet metal'd up for upstairs fresh air ducts.
Along this wall, I will need to add 2x4 along the edge for a face to nail drywall to. Will I need to remove the sheet metal, add 2x4 for face to nail drywall to under the ducting or can i simply screw the drywall into the sheet and that will provide sufficient support for the drywall?
Thoughts?
Thanks in advance!
Thoughts?
Thanks in advance!
You don't necessarily need to nail the drywall to anything at the edge of the room where the pan is. You hang the ceiling first, and the drywall you put on the walls will hold up the edge of the ceiling. The pan itself will prevent the ceiling drywall from being pushed up too high.
In areas where there is no pan, you would put blocking as you normally would. But in the areas where the pan is, I would recommend that you do not screw anything to the edge of the pan.
