What to do about inaccessible crawl space
Old 08-16-16, 05:27 PM
Received 32 Upvotes on 23 Posts
My house has an inaccessible crawl space (the kind on the bottom of the house, not in the attic). And I guess if it's inaccessible, is it really a crawl space? Anyway... The house is old, and has a fieldstone foundation, with several additions. I don't know exactly how the additions went on, but in the end, the house is square, and 3/4 of it has a basement, and 1/4 does not.
That quarter without a basement has new HVAC run to it, and had old ductwork removed as evidenced by the plywood patch in the old floor. So obviously, access was made at some point. Currently, though, there's only a slight gap around where the ductwork penetrates through the old stone wall. It looks like they may have taken out some stones to crawl in, then replaced them and sealed up with mortar when they were done.
I know that the "floor" of the crawlspace is dirt, since I removed one of the old plywood floor patches to peek in, but nobody is fitting through that patch opening. I'm concerned that the crawlspace is essentially 100% sealed up, and that there may be moisture, critter, toxic waste dump, or other manner of unholiness happening that I can't see and won't know about until it's too late. I got more concerned when I noticed the floor getting a little squeaky and bouncy in one spot, but I can't tell why.
So, am I right to be concerned, or should I just let it be? I would imagine a scuttle could be added from the basement to the crawl space, but I would also imagine that would require perhaps an engineer to figure out the best way to remove the stone and build said scuttle.
Old 08-16-16, 06:46 PM
Received 3,422 Upvotes on 3,068 Posts
A picture or two of the basement/wall area would be helpful. http://www.doityourself.com/forum/el...-pictures.html
I don't think you'll need an engineer but you'll need a good mason.
The condition of the wall needs to be assessed before any work can be done.
Old 08-16-16, 07:54 PM
ray2047's Avatar
Is there a closet over the crawl space? If so you could put in a trap door or simpler just a removable panel.
Old 08-16-16, 08:32 PM
Nope, no closet. The dining room is over the crawl space, and I doubt the wife would go for a trap door in the floor there. We had thought about trying to use the old HVAC patch as a trap door/scuttle, but the problem is the foundation is so thick that once you lift the patch out, you're still over the foundation wall. You could probably squeeze a greased toddler in, but not an adult.
So, the original basement walls have been reinforced with concrete block. The only area that's really accessible, because of the double-wall, is this odd opening. Again, like somebody had an access opening there, and sealed it up.
Looking up in there, you can see that framing definitely bears on the stone.
And FWIW, the galvanized pipe in there is old and disconnected, as is the copper on the left. The pipe on the right is in use. Oh, and the main sewer line runs in front of the opening about a foot and a half away. Not impossible access, but not great.
