flooded crawl space
flooded crawl space
Was looking at purchasing a cabin lake side but during last major storm the lake rose and flooded the crawl space. What should I expect the owner to do prior to my purchase? There is nothing in the crawl space, no vapor barrier only dirt floor. Just looking for some thoughts on what I should request from the owner prior to purchase. I realize don't purchase maybe be the smartest move but a really nice spot and not prone to flooding but major storms do present a problem.
Also is there anyway of waterproofing the crawl space to prevent this type of flooding?
Welcome to the forums! There's not much you can do, preemptively, to stop such flooding. The water will rise, no matter what. In addition most insurance policies do not cover rising water, without a flood rider.
Not sure you could get the seller to do more than pump out the crawlspace.
I assume the water came from the lake rising ? Did the water enter thru the crawlspace access door?
Other than erecting some type of barrier there isn't a lot you can do to prevent re occurrence. Obviously any voids in the foundation would be patched/sealed.
A concrete floor makes for easier clean up, but doubt you will get the current owner to go for that. If you have electricity you could install a couple sump pits to maybe hold off some floods.
Are you talking 1 inch or one foot of water?
Bud
Bud
If it was me I would pass on buying it.
Wet basements cause all kinds of issues.
What goods it going to do to add pumps to get the water out if the whole area is already flooded during a wet event?
Willing to spend many thousands of dollars, the house could be raised, under the house backfilled to get it above the flood zone, opening for crawl space raised, outside of foundation sealed, top of foundation added onto, flood door added to crawlspace access.
Re: flooded crawl space
Thanks for the info, the crawl space was fully flooded (3 feet), so I was wondering how it would need to be dried out, what to look for in terms of previous flooding (owner says it was first time) with respect to wood foundation being water logged etc. Just need a drying out period? Maybe something I should just walk away from.
The time frame to dry it out is not weeks, but one or two days.
I don't go for the "first time it ever happened explanation". It happened and the current owner is the one who should take the hit on value.
I like Joe's suggestion of raising the house several feet and filling the crawlspace. But at 3' the house would have to be raised 6', plus surrounding landscaping, to be confident the problem is solved. Looks like you should pass unless the current owner will make that kind of adjustment. Not even sure the landscaping can handle that. Maybe stilts.
Bud
Bud
Walk away? I'd run away from this.
My in-laws used to have a townhome in a marina on a river nearby. Every spring they would flood. The bottom level was the garage so no living space was affected but the amount of mold that appeared in the few years they lived there was unbelievable. That may have affected my judgment regarding flooded dwellings.
Across town from where I grew up was a nice riverfront community - but it flooded more springs than not. Those houses were always for sale. People would buy thinking the flooding is worth it to be along the river .... until it happened. I found it amusing that there were no shortage of folks willing to buy, knowing the flood risk was high.
re:flooded crawl space
Thanks again guys, I have decided to walk away and continue to look for a cabin in a flood free zone. Asked the owner for one final look at the crawl space after it was drained and there were red flags so rather than risk having to sink big dollars after purchase told the owner I had to end the sale negotiation.
