Basement bathroom with concrete floor
Received 0 Votes
I have an older home with a bathroom in the basement. I recently had to tear everything out because the previous owner used drywall under the tile in the shower. So I am essentially starting from scratch. I will need new flooring. Currently there is tile over the concrete slab. I was wonder what i needed to do to make my slab capable of being the floor for my bathroom similar to this picture
http://shazzamstudios.com/wp-content...-Bathroom2.jpg
Is that polished concrete in the picture?
If so, you need to remove the tile and adhesive and have the slab polished and sealed.
FYI - I deleted your other thread on this as a duplicate.
Yeah, I assumed you would hire something like that out and see the estimates as being way too high.
FWIW, tile is about as usable as anything and it sounds like you have that now.
Floor glue just gums up anything you attempt to use to remove it. Doesn't scrape well, sanding discs last about 3 minutes before they are toast. Solvents will most likely knock you out from fumes.
Tile with a good Thinset mortar that is designed to go over cutback adhesive would be the easiest path to take.
