Adding Insulation Under Floor
I recently had an addition built on helical piles and had the underfloor insulated with spray foam (see attached image). The insulation does an "ok" job but I feel the floor is still a bit on the cool side in the winter. The crawl space in the image is still a ventilated space even although I have added lattice around the perimeter.
Would there be any benefit to adding sheets of expanded polystyrene board to the underside of the joists shown in the attached image ? The EPS Sheathing has a R8 value .
Would it help. Yes. Would you be able to notice... maybe not.
How much insulation R value is in the floor already? Spray foam has an R value of about 6 per inch of thickness. If you already have 6 inches then you have an R 36 floor. Adding R8 insulation will help but is only about a 20% improvement to go from R36 to R44. 20% is significant but you might not notice it. If your floor had nothing it might have an R value of 2 and adding insulation with R8 would be a huge increase and very noticeable.
The r-value affects the heat loss, double the r-value and halve the heat loss. But doubling the r-value only makes a small difference in surface temp and surface temp is what you share with those floors. Citations available.
Bud
Bud
