Best way to make a crawl space under existing ranch style home
Received 0 Votes
Family member wants to put a crawl space under his the house he recently bought and is remodeling. Just trying to get an idea on what this is gonna take. Is it something take has to be professionally done? Can it be a do-it yourself project? Any info would be greatly appreciated!
I've seen houses on slabs moved before so maybe a company that can raise the house and install a foundation along with additional supports as needed. It won't be cheap!
A) concrete slab= forget it.
B) piers and beams = possible but a total P-I-T-A.
C) perimeter foundation = possible, but likely to be more work than it's worth.
GOOD
An industrious uncle of mine EXTENDED the basemen of an old farmhouse, from a 5' hand dug basement to a full height 8', but that required alot of jack hammering, ~ 5,000 trips with wheel barrow, and a generous setback from the walls, with shotcrete and rebar tiebacks for stability, to ensure that digging below the foundation didn't casue the foundation to shift.
BAD
I've shown buyers a foreclosure rancher where the prior owner used a Bobcat to dig out a basement, house sits on a hill, owner dug a ramp down to ~ 8' beneath the house floor, chiseled a 7' wide hole in the block foundation and used a Bobcat to dig out a basement, unfortunately, he didn't shore up the edges of the new entrance and the foundation buckled in- about 10' on either side of the hole.
He walked away, and the house went back to the bank.
