Opinions needed for a basement ceiling
My wife wants to finish part of our basement and install a wood burning stove. We had a flue installed when the house was built three years ago. So most of the logistics for the stove has been taken care of.
I'm trying to figure out a relatively cheap/easy way to finish the basement ceiling. I thought about dropping the ceiling to hide pipes and ductwork, but also want access in case of water leaks, etc.
One of the ideas I had was to construct a 4'x4' grid underneath the ductwork/pipes using 2x6s and 1x4s to create an upside down "T". When lay wainscot paneling inside the grid, supported by the edge of the 1x edge.
The wainscot panels are 24lbs per 4x8 sheet. So there wouldn't be a lot of extra weight. Unfortunately, the specifications for the wainscot panels states 'not for ceiling use'.
Is there a reason they are 'not for ceiling use'? Or does anyone here have a better idea?
Thanks in advance!
Thanks in advance!
This is what I installed, Armstrong country planks, they are glued to furring strips and although they are not as easy to get above I have everything mapped out and replacing the planks is simple as found out when we had to run a new cable tv line.
https://www.doityourself.com/forum/a...1&d=1543066449
Yep, I found the thickness of the wainscot, it is thin. The Armstrong Country planks look good, I might go that route. Thanks!
