Basement control lines
Old 12-19-18, 09:57 AM
G
So I tore up some old carpet in my basement and the ďcontrol linesĒ, I believe thatís what they are called, are filled in with some white colored material. It is hard, but doesnít appear to be a self leveling of any kind. It is cracked in some areas so Iíve decided to remove all of it from the control lines and fill with something else, so it is more smooth and level.
My question is, what do I fill the control lines with? Should I use a self leveling compound that I pour in the lines, some sort of gap filler that comes in a tube like caulk? I should note that I am going to carpet over top.
Note: I live in Colorado and my basement has never appeared to have gotten any water or moisture.
Old 12-19-18, 10:25 AM
P
Received 681 Votes on 628 Posts
You don't have to put anything in the cracks or control joints. There are sealants made especially for expansion and control joints. But, since nothing is needed in the joints you can use about anything you want from nothing to silicone caulk, acrylic caulk...
Old 12-19-18, 11:07 AM
G
I was worried if I didnít put anything in the control joints and just put pad down and then carpet, you would feel the control joints when you walked around.
Old 12-19-18, 01:30 PM
P
You can fill them in if you are concerned. If you want the joints to be hard/solid like the floor you could fill with mortar or thinset mortar. That would be easy to trowel into the joints and scrape to get a smooth, flush finish. It won't affect the function of the control joints.
