Ideas to finish this in basement
Finishing my basement with 2" polyiso, 2x4, s/r as seen on the left. There is a gas vented heater installed that I put 1" polyiso behind the lines, then I went back to 2" polyiso to the right of the heater, which goes under the stairs on the right. I think there's a clearance of 6" or so to parts of the heater for walls.
I'm wondering why put a 2x4 wall under the stairs? But then I'd like to finish the area so the basement is livable and clean eventually, after installing window sills/trim and putting in flooring and a ceiling.
Anything obvious that you would do the finish this off?
