Inexpensive ceiling for partial basement coverage
Received 0 Votes
Hello,
I am looking for a very inexpensive way of safely covering a part of the ceiling in our basement under which our baby sitter will be sleeping.
https://*******/MMvJDJT
https://*******/fr852SR
Here are a couple of pictures of the area.
I searched on the forum and vinyl soffit caught my eye as potentially the most inexpensive option, but after searching around a bit the safety of that option seemed to come under fire. Looking for thoughts and ideas.
Thank you for your time.
Alex
Alex
Welcome to the forums!
Your links don't work. https://www.doityourself.com/forum/e...-pictures.html
A drop or suspended ceiling is likely your best bet. For a bed rm to be legal it needs a means of egress, does this room have a window? if so, what size?
Received 0 Votes
Hi Mark,
Thank you for the warm welcome! My files were too big so I hoped I could get by with links. The pictures are attached here now. As you can see from the picture we had a legal egress window installed when we cleaned up the basement. It's not truly finished, just cleaned up and inexpensively carpeted.
Our baby sitter says she doesn't want to sleep under an open ceiling, so we're trying to accommodate without investing significantly as we'd plan to actually do the basement (bathroom, walls, ceiling) in 2-3 years.
So you don't think vinyl is a real option?
Thank you,
Alex
Thank you,
Alex
Welcome to the forum.
Look into a drop ceiling using tiles. It's possible you can run a series of furring strips (assuming you have the clearance) which would be cheapest and glue the ceiling tiles to them or you can get a kit which would be easiest. Some electrical will probably be required as well for the lights.
Alternatively, you could use furring strips and put up sheetrock but then you'll have issues with gaps.
Not sure how the installation would be in that space but drywall is actually pretty cheap compared to most other choices. Doesn't sounds like you would need to mud and tape if you didn't want to finish it now.
Received 0 Votes
Hi Tony, I looked into furring strips. So it's basically just pieces of wood nailed or screwed into the main ceiling beams (joists?) I'd glue foam tiles to them?
Do I stack the furring strips to lower the ceiling below the height of the pipes or do I place one perpendicular to the joists and then build off of the bottom, essentially creating a wooden frame similar to a metal drop frame?
Dan, I love the canopy bed idea!!
I do not know why you seem against a drop ceiling?
It is the simplest solution.
When you do renovate the basement you can take it down and perhaps reuse it in a utility or laundry room where you want access to electrical, plumbing etc.
