Faced or unfaced insulation
Old 03-31-23, 11:58 AM
I have a finished basement. One room has to be done over because of a water leak. I wasn't here when they tore out the wall and insulation. For the basement wall do I use faced or unfaced insulation? There is foam on the wall itself right now so I'm asking about between the studs. Also, there is faced insulation in the ceiling. I read conflicting articles on this. Faced or unfaced on walls and ceiling? I live in Colorado which has low humidity.
Old 03-31-23, 01:27 PM
Received 4,051 Upvotes on 3,634 Posts
For interior walls you don't need to use faced insulation.
I've always used at least Kraft paper backed insulation as it makes the installation cleaner and neater.
I hate insulating.
With outside wall you need to consider a vapor barrier.
mickeyrory voted this post useful.
Old 03-31-23, 04:39 PM
XSleeper's Avatar
Received 1,948 Upvotes on 1,748 Posts
Current opinion is that you do not use a vapor barrier on fiberglass insulation in exterior walls when those walls are below grade.
See IRC R702.7(2)
Old 04-01-23, 09:04 PM
Received 1,273 Upvotes on 1,213 Posts
I'm with X on no vapor barrier below ground. Since the paper is a vapor retarder, I would skip it.
Old 04-01-23, 10:01 PM
B
Received 47 Upvotes on 43 Posts
I would suggest you consider mineral wool over fiberglass. It fits snug and will stay in place.
How thick is the foam that is currently there?
Bud
Old 04-02-23, 06:00 AM
Tolyn Ironhand's Avatar
Received 893 Upvotes on 754 Posts
Properly sized unfaced fiberglass will stay in place between the studs. I find unfaced easier to install, if a vapor barrier is needed/required, then use plastic sheeting.
