Advise needed. How to unmount roller blind
Hi,
I am trying to remove a 6 years old roller blind installation, but I have no clue how to begin.
I recalled briefly it is supposed to be a spring clip on thingy but this is as far as I can remember.
Pls see attached with the view of the mounting bracket.
CL
CL
The button is like a latch. You push the latch to the side, (left) then grasp the whole roller blind and give it a sharp yank straight out to pop it off the mount. Since each blind has multiple latches, you do them one at a time... moving them each just a lititle bit until all the latches have been released.
It might help you to get on a chair or ladder so that the blind is right in front of you. You don't pull down on the blind at all... just out... perpendicular to the wall.
If it helps, this is likely your care manual: https://cdn2.hunterdouglas.com/stati...te-install.pdf
