My hot water baseboard heaters are not working
Old 10-09-16, 03:20 PM
H
Question My hot water baseboard heaters are not working
As I ran some diagnoses that I read on the internet, I found my situation was special.
When I turned on and up at least 5 degrees over the room temperature the baseboard heaters after I loosened the bleed valves on the pipes inside them, there was only air coming out. Unlike those troubleshooting on the Internet which were involving
1.nothing
2.no air but only water came out,
Mine was only air.
So what could be the problem?
Old 10-09-16, 03:38 PM
G
Received 27 Upvotes on 26 Posts
What is the temp and pressure of the boiler? It's possible that when you opened a bleeder valve, air was sucked in, but is sounded like air coming out.
