Boiler not turning on
Old 10-01-17, 11:23 AM
B
I have a Utica boiler providing heat to two floors with two thermostats . Turned up the thermostats to test for winter and no heat.
I have done the following so far:
replaced batteries in the thermos
blew out dust in thermos
lines have no air in them, cold water comes out
tested zone valves by turning on thermos separately and could hear the valves working on both
boiler seems to have proper water pressure and no leaks anywhere
Any ideas of what I missed or what the next step is? Thanks very much
Old 10-01-17, 03:18 PM
Received 141 Upvotes on 133 Posts
Make sure there is power to the boiler and if all the switches are on including the one upstairs if you have oil. If you have power try hitting the reset button to see if it shut down for some reason.
Hope this helps a little.
Old 10-02-17, 07:00 AM
D
Received 105 Upvotes on 99 Posts
It would help to know whether boiler is gas or oil fired and what type of control it has. A picture and model number would be a good start.
Old 10-09-17, 07:51 AM
B
issue resolved
thanks for the advice. the problem apparently was the circuit board on the boiler. thanks again
