Wireless thermostats in place of wired
Old 10-14-17, 06:50 PM
I
Hi all,
I believe I've worked out the answer to my question (and I hate to beat a dead horse on this topic), but I'd like confirmation (or correction) from those of you more knowledgeable so that I don't inadvertently blow something up.
Here's what I'm planning: Zoning a single zone hydronic baseboard oil fired system into 3 separate zones. I'm planning on using a Honeywell HZ322 panel, wireless adapter THM4000R1000, and 3 TH6320R1004 wireless thermostats in place of the current single Honeywell RTH221B1000 thermostat. I'll be adding 3 Taco Z075C2-1 zone valves to use with the current Taco 007-F4 circulator.
Based on the documentation provided with the panel, tstats, & valves, the wiringseems straightforward; my question is about wiring it to the existing boiler controls. (Pics of the current setup are at the end of the post).
The plan is simply to replace the current tstat connection (wired to the R & W terminals in the CA-295) with a connection from zone valve end switches. Per the zone panel wiring schematic, "Wire the end switch from each valve in parallel to the R and W or T and T at the aquastat or boiler." I believe I just need to wire up a separate 24VAC transformer to power the panel & valves.
Am I on the right track? Thanks in advance!
Here's the current setup:
https://photos.app.goo.gl/F0mUGqQU4g85JXdH3
COMPONENTS
Arcoleader A1 4P boiler
https://photos.app.goo.gl/BCUVltZE27RgnOng2
Tstat to Detroit CA-295 switching relay
Schematic: https://photos.app.goo.gl/rmmjZFU6KDLihzWG3
Current wiring: https://photos.app.goo.gl/f33Un88DAqqYi7Mv2
Carlin 100CRD
https://photos.app.goo.gl/XncqDaRZOXu4lDrN2
Detroit CA-655 high limit control
https://photos.app.goo.gl/18TTbmY7w7iUVdVE2
Honeywell aquastat (low limit control?)
https://photos.app.goo.gl/aQGHHRkiYidNDVj73
Old 10-15-17, 09:41 AM
Received 4,155 Upvotes on 3,731 Posts
Welcome to the forums.
I'd guess you could use the Honeywell HZ322 for hydronic switching. I've never seen it used that way as it's designed to zone ductwork dampers. One thing that would need to be confirmed is that the output of the TruZone has enough capacity to operate zone vales.
Old 10-15-17, 10:20 AM
I
Hi Pete,
Thanks for the reply. It does look like the HZ322 can be used in hydronic systems with zone valves. Bottom of page 6 is the schematic I was working from:
https://s3.amazonaws.com/s3.supplyho...322-Wiring.pdf
Old 10-23-17, 07:14 PM
I
Hey guys, just wanted to give a follow up. Everything went as planned and all seems to be working well.
Old 10-23-17, 08:04 PM
Awesome news. Good job. Thanks for stopping back and letting us know.
