Boiler fires but no hot water at taps
Old 10-06-18, 02:34 PM
E
My domestic hot water stopped mid shower today. The boiler is firing and the pipe leading to the indirect water heater is hot on both sides of the Taco circulator pump. The boiler seems to be running a little hot and the baseboard hot water system is working and puts off heat. Any thoughts?
Old 10-06-18, 03:19 PM
Received 1,107 Votes on 1,027 Posts
Please post some pictures of your setup...... How-to-insert-pictures
The circulator has nothing to do with the domestic hot water unless it's supplying a separate storage tank.
Old 10-06-18, 03:27 PM
E
Update. So after running the baseboard heating I know have hot water again. Everyone of the taps gurgled and put some air out but then I got hot water again. I don't have a clue of how I "fixed it" but any thoughts as to what happened?
Old 10-06-18, 03:29 PM
Nope.... not without knowing what you have there.
Old 10-06-18, 03:38 PM
E
I can take more if you would like.
Old 10-06-18, 03:59 PM
So your boiler supplies a storage tank thru its own circulator pump.
It was hot on either side of the pump. But was it hot on the return line from the tank to the boiler ?
Is there a gauge on the storage tank ?
Old 10-06-18, 04:07 PM
E
The return line from the tank was not hot at all but now it is. Tank has no gauge.
