Draining a gas fired boiler for baseboard replacement
I need some help, I am remodeling my basement bathroom and the baseboard radiator is in pretty poor shape and I would like to replace it. The problem I have is that my boiler is in a room off the garage and the baseboard radiator (the whole zone actually) is in the basement which is lower than any of the drains in the boiler room. I have looked at all the baseboard radiators in the basement zone and none of them have a low point drain. What is the best way to drain the zone? The radiator in question has 1/2" pex pipe supply. Any help would be appreciated.
Thanks,
Dan
Thanks,
Dan
Welcome to the forums.
First off you need to make sure all the supply valves are turned off.
Ultimately you'll need to cut the line to get it to drain. Do you have a place to drain it to ?
PEX is often connected with special fittings that can be easily disconnected with an inexpensive little tool - SharkBite is one brand. The same connectors and PEX tubing can be reused.
