Pressure gauge on boiler
Old 02-18-19, 10:39 AM
B
i have a bunch of posts cant find them? i replaced chamber unit relief valve and pressure gauge furnace has been working fine.i noticed gauge goes up to 30 psi.seem high. this is a 1986 dunkirk steam furnace thanks for any help
Old 02-18-19, 11:24 AM
Received 141 Upvotes on 133 Posts
b,
Found your old posts. Your relief valve should go off at 15 PSI. As previously mentioned you do not need any more than 2 PSI in to run your boiler. Your boiler is a 1984 Dunkirk as stated in an older post.
Pics would be helpful if possible to see the equipment.
Old 02-18-19, 11:40 AM
Shadeladie's Avatar
Super Moderator
Received 407 Upvotes on 334 Posts
Just click on your name and pick "find all posts" to find your previous posts.
I think this is the thread you're looking for:
Fire brick?
Old 02-18-19, 05:03 PM
B
what makes the pressure go so high?
Old 02-18-19, 05:29 PM
Is your relief valve going off. If not, either your gauge is defective or your relief valve is defective. Your pressuretrol settings controls your high limit.
Old 02-20-19, 02:58 AM
Received 14 Upvotes on 11 Posts
If your boiler is a steam boiler and the steam pressure is actually raising to 30 psi with a 15 steam safety valve, which is the correct pressure rating for a steam boiler, it is time to have someone fix this problem immediately and I mean right now, before this boiler hurts you or your family. This is what we call a "run away boiler" and it is very dangerous.
