bell and gossett coupler clanking upon startup
Old 10-15-19, 02:44 PM
A
Bell and gossett coupler is not working correctly
Old 10-15-19, 02:49 PM
A
Just installed an new spring and coupler and am thinking they are supposed to be "coupled" after setting the set screws with allen wrench to motor spindles.
Old 10-15-19, 02:55 PM
A
Received 67 Votes on 61 Posts
Welcome. The two halves are coupled by the springs. It's been a bit since I did one, but should be 4 springs as I recall.
Old 10-15-19, 05:26 PM
G
Received 11 Votes on 11 Posts
My solution would be to replace the pump with a wet-rotor pump.
Old 10-16-19, 05:18 AM
Received 5 Votes on 5 Posts
A picture of the pump and coupler would be helpful. When you tightened the allen screws did they go into the shaft indentations? They are easy to install correctly, once you get the "hang" of it . Did you use the right coupler? How old is this pump and motor?
