Concrete flower bed
Received 0 Votes
Concrete flower bed
A tree's multi-root system knocked the rebar right out this concrete flower bed border.
How would you fix this?
You could line it back up, remove the loose, build a form and pour in a concrete patch but even with the tree removed it will still be a temporary fix. As Joe pointed out you'd need some sort of footer for it to be able to withstand the test of time.
Received 0 Votes
Originally Posted by joecaption
There is no "fixing it".
I agree 100% tree needs to go.
Unless that concrete curb was laid over a proper footing it's not going to work.
Generally there is a concrete footer poured down to the frost line and at least 1' wide, since it isn't structural a gravel footer is probably acceptable. From the pics it looks like it was just formed up over the grade and poured [sitting on top of the ground]
Mark, I think the OP is in Florida. You'll probably hit water before you reach the frost line.
It's not a structural piece, just a flower bed border. I would just put it back in place, build a form and pour new concrete around the damaged part.
My memory isn't all that great but I'm thinking the 'official' frost line for central fla is 8" IMO it is more about having a stable base than any frost heave worries
The mythical "frost depth" really only applies for structures based on the likelihood for 50 to 100 years that would cause structural damage. I have see the frost to go down 6" after aver a month of days with lows of -5F to -40F and highs below -0F. There was only a few inches of snow for protection.
Landscaping is not applicable unless there is major heaving to cause.
Dick
Dick
Received 0 Votes
Received 0 Votes
Thanks!
I was thinking I could try to use a crow bar to hook it from underneath to try to move the bottom back first. How exactly would you use the 2x4 between bar & curb?
