Advice on building block island for grill
Old 03-16-16, 07:39 PM
Im planning on adding counters/island to the sides of a bbq grill. I want to build them out of block and then either tile them or give them a sand finish. Ive never really worked with block before so im kind of clueless.
Can i lay a slab of concrete down outlining the counters/bbq and build the block wall on top of it? How thick does the slab need to be?
Once i build the perimeter of block how do i attach a counter surface on it? I do not want to place a slab of granite on top as it is expensive. I think i will go with a tile surface countertop as well.
Im undecided if i want to place the grill in the corner still because my fence is at a weird angle (not 90) heres a pic http://i.imgur.com/lieRbRp.jpg
Old 03-16-16, 11:07 PM
P
Temporarily Suspended
Even though there is no frost line in AZ, I don't know if footings are needed under the slab. Local builders would know.
What about a blue stone slab?
Old 03-17-16, 07:35 AM
I think i might pour a footing to get a nice level surface first. I had two slabs of cheap granite which i was originally going to use as the counters but they both have the corners chipped off about a good foot. The surface area is going to be about 2ft long on front 3 ft long up on the fence and 2 feet wide. Is blue stone really that affordable?
Old 03-17-16, 08:01 AM
P
I presumed that it was cheaper than granite. The best way to verify that is to call a local stone yard & see what they have to offer.
Old 03-17-16, 10:23 PM
BridgeMan45's Avatar
Received 2 Upvotes on 2 Posts
As a minimum, a thickened slab will be necessary, to prevent the weight of your block construction from cracking a typical slab.
