Risers of brick stairs
Old 08-21-16, 08:15 PM
K
Received 3 Votes on 3 Posts
The outdoor steps to our split broke. Took a while but finally fixed it ... Replaced field stones with granite, replaced some loose bricks, reprinted all joints
Now, I need to repair the risers. The risers are broken in some places. I chiseled out the pieces. Now the big questions are
1) what do I use to repair the risers -- regular mortar or something else ?
2) how to apply mortar ( or whatever I use )
3) how to make it a smooth, level surface. Asking because whenever I try to apply mortar to a vertical surface, it falls of
Old 08-22-16, 03:25 AM
chandler's Avatar
Received 6 Votes on 6 Posts
It would help us to help you if we could see what you see. Can you post a couple of pictures showing what the project looks like? http://www.doityourself.com/forum/el...your-post.html
Old 08-25-16, 05:16 PM
K
Sorry for the delay ... here are pictures. The bricks have been repointed using quikrete mortar mix and need to be cleaned (using 50% acid+50% water -- right?)
My question is what do I use for risers and how do I smooth it.
I purchased a tub ready mix quick dry but did not open yet.
