High temp adhesive for brick veneer?
Old 10-07-16, 09:13 AM
0
Installing brick veneer around a direct vent gas fireplace that is sealed in the front by a glass panel. Model is GNRC33
The heat from the fireplace mainly comes from the top "vent" of the fire place on the front into the room. I was wanting to install a brick veneer around the fire place. And after feeling the heat that comes from the fireplace I don't think a standard mastic will work. is there something that is recommended for installation around a fireplace? As most of the construction adhesives I have found are only good up to 120 F and the temperature that I measured got right around 120 so not comfortable using it at the top of its rating.
thanks for any help.
Old 10-08-16, 07:54 PM
B
Received 3 Votes on 3 Posts
I would suggest calling tech support for one or two of the major manufacturer's of construction adhesives and see what they can suggest.
Old 10-09-16, 09:49 AM
Received 79 Votes on 74 Posts
Got a picture so we can see what it is your trying to do?
What material is it your trying to stick it to?
Old 10-09-16, 11:19 AM
Tolyn Ironhand's Avatar
Received 223 Votes on 196 Posts
I would use a modified thinset, or a masonry produce, rather than something that comes out of a tube or bucket.
