Xypex alternative
Old 01-11-17, 07:00 PM
D
Xypex alternative
I have water coming into my basement around the sewer pipe cleanout that passes through the foundation wall. A few years back I had the sewer line replaced. It turns out they did not use an asphalt collar around the pipe through the foundation wall.
A close friend who is a very seasoned architect recommended two remedial measures. One was to coat the bare cement around the pipe with Xypex. Trouble is, Xypex appears to come only in large sizes @ $178.00 each. Is there any less expensive alternative? I need to cover only 2 square feet of wall.
Thanks.
Old 01-12-17, 05:22 AM
P
Received 1,956 Upvotes on 1,752 Posts
Personally I think water must always be stopped outside the basement wall. If you excavate outside you can use any number of methods to seal the pipe. Hydraulic grout/cement to fill the gap around the pipe and create a fillet and then coat with foundation damp proofing compound (tar) works quite well and is inexpensive.
Old 01-12-17, 10:01 AM
Received 1,232 Upvotes on 1,180 Posts
I'm with Dane, always start outside with water if you can.
