Best time of the year to drive a heavy load across asphalt driveway
Old 01-27-17, 06:08 PM
C
I had my driveway topped late last spring, adding a 2 inch top over the old asphalt. In order to have my septic tank pumped the truck will have to back up the driveway and onto my yard. The yard is 1-2 inches lower than the driveway. I can ask them to send an empty truck rather then one half full (10,000 gallons when full). Even so I am concerned about the truck cracking the edge of the drive. Would I be better to wait until summer when the asphalt is warm from the sun, or do it in the winter when the ground is frozen?
Old 01-27-17, 06:13 PM
XSleeper's Avatar
Received 714 Votes on 661 Posts
I would have it done when the ground is frozen.
Old 01-28-17, 03:55 AM
czizzi's Avatar
Received 14 Votes on 12 Posts
Have them place multiple layers of plywood to raise the level up even or higher than the driveway. They have done this before and probably have the material available.
Old 01-28-17, 05:05 AM
V
Received 1 Vote on 1 Post
What's the total distance from the road to the Septic Tank ?
They may come equipped with an extra length suction hose.
Old 01-28-17, 06:54 AM
Marq1's Avatar
Received 392 Votes on 366 Posts
My septic company will not go on any drive, they come with many sections of hose, find another company, dont take the chance!
Old 02-10-17, 06:28 PM
I've never seen a semi tanker used for septic service. Most are either single or double axle trucks that hold at the most 3000 gallons. A tractor-trailer pump truck would be a problem to get into many places. Are you sure that's what they are going to use?
Definitely agree with the previous poster regarding doing it on the ground is frozen.
