Water coming through cinder block foundation
The bulk of our house is built on a poured foundation and that's fine. There's no water getting through it during rain. However, under the laundry room, it switches to a crawlspace and uses a cinder block foundation. Between the two foundations is a gap and water has flown in an eroded most of the dirt fill supporting the foundations. We happened to have a heavy rain a few days ago and I opened up the crawl space and I noticed there was water coming through the cinder blocks and pooling in the crawl space/
Is this something I need to be concerned with? I plan on adding more back fill to replace the missing dirt. I should also add that the joints on the cinder blocks need to be repointed but I'll get to that some day.
You need to regrade on the outside to move the water away from the wall in the first place. Yes, this is something about which you should be VERY concerned.
How far below grade is the gap? I would dig/excavate on the outside so you can fill the crack from both sides using type S mortar. Then I would apply a damp proof coating (tar) to the exterior before back filling.
The gap goes from the top of the foundation and most likely goes all the way to the bottom of the foundation. Would I also need to apply the damp proof coating to the cinder blocks that are on the garage? I'll post some photo's later.
https://www.lowes.com/pd/UGL-White-W...-fl-oz/3073099 I found this. Would this work?
I talked to my dad about what we need to do and he figured that we'd have to do this. This is my basic plan. Is there any other steps that I should do?
Also, what tool do you all recommend to apply the mortar? There's a tool for repointing but I don't remember the name.
- Excavate the foundation
- Remove loose mortar and clean the the area of dirt and debris
- Fill the gap with mortar and repoint any loose joints on the cinder blocks
- Let the mortar dry and apply one or two coats of damp proofness
- Backfill
- Done!
You can use a grout bag to squirt mortar into the crack but I generally use a trowel. Or if you wear gloves you can use your hands to pack it in.
I would use a wire brush to clean the foundation on either side of the crack to get it good and clean before applying a damp proofing. How far you go away from the crack depends on your energy level but I'd go 6-12".
